Viore PD50VH80 50" Plasma`
  • kevinm34232
    • May 2012
    • 1884
    Label on back was removed, not sure of model # but think it's VIORE PD50VH80
    TV is dead. 120VAC to PS, but 0VAC at bridge rectifier. Fuse is good.
    Power Supply is a Samsung LJ44-00188A
    Panel # S50HW-YB05 (S50HW-YD13)
    What should I check? Thanks!
    Re: Viore PD50VH80 50" Plasma`
    Do you hear a relay click when power is applied? Any 5V STBY?
    • kevinm34232
      • May 2012
      • 1884
      No click and no standby
        Can you post a picture of what's under the 450V 22uF capacitor? (gold coloured)
        https://www.badcaps.net/forum/attach...2&d=1371936170
        • kevinm34232
          • May 2012
          • 1884
          • kevinm34232
            • May 2012
            • 1884
            I just checked the nearby Q5801 and Q5802 (TK15A50D) and there is 22 ohms between gate and source on both of them.
              Some test points.
              RED-BLACK: Check voltage between these points. Should be around 160V DC.
              BLUE: Measure voltage across this capacitor.
              • kevinm34232
                • May 2012
                • 1884
                0.7VDC between resistor and diode, 0V at that cap, remember I'm getting no AC at bridge rectifier does that mean a problem in the AC section?
                  The bridge rectifier is only used when the 2nd relay clicks in. 1st relay is inrush limiter.
                  However this NTC appears to be used for both the 22uF cap and main power circuit.
                  So please check the resistance of it in circuit.
                  If it is bad, the bridge may be bad (shorted.)
                  • kevinm34232
                    • May 2012
                    • 1884
                    Is 22 ohms. The bridge tested good in circuit.
                      If you measure the AC at the left most terminal in the above picture (red probe) and black probe on the right most pin of the power connector from the AC plug (again as in photo), what do you measure? Somewhere the 120VAC is disappearing and it's probably in that filter section somewhere.
                      • kevinm34232
                        • May 2012
                        • 1884
                        I have 122VAC here between those pins.
                          Sanity check, let's try another way for measuring standby cap voltage.
                            D'oh. Idiot alert. Please place the black probe on the fuse, not the resistor. Also, check that fuse is not blown.
                            • kevinm34232
                              • May 2012
                              • 1884
                              VX801S
                              Black probe on white main, only readings on one side..
                                What is white main mean for black probe?
                                • kevinm34232
                                  • May 2012
                                  • 1884
                                  There is no voltage from that fuse to the cap, and fuse is good.
                                  • kevinm34232
                                    • May 2012
                                    • 1884
                                    I mean the pin 2 white wire on the main AC connector
                                      Well, the AC is disappearing somewhere. I'll see if I can track down a schematic for this, but it shouldn't be too difficult to figure out at what point it stops.
                                      • kevinm34232
                                        • May 2012
                                        • 1884
                                        Should I have 120VAC on both sides of this component?
                                        • KYBOSH
                                          VIORE PDP4210EA Plasma TV 42 inch - No Video on DVI
                                          by KYBOSH
                                          Got my hands on an relatively unknown TV brand about two weeks ago.
                                          I certainly hadn't heard of it before.
                                          Previous owner didn't give a description of what was wrong and when I got it the back cover was already off.
                                          I put it on the back burner until I had so spare time to look it over.
                                          Today was that day.
                                          I plugged it in and was surprised to see that it started up without any issues.
                                          This is an older TV and the most modern video input that it has is DVI.
                                          I was scrambling to find a DVI connector or adapter as I haven't fooled with that...
                                          01-27-2023, 08:19 PM
                                        • ArMaaN376
                                          Samsung PS51E550 Plasma TV
                                          by ArMaaN376
                                          I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                                          Opened TV cover & observed foll
                                          a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                                          b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                                          c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                                          How to confirm Y -Buffer board...
                                          06-19-2024, 04:05 AM
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
                                        • KYBOSH
                                          Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                          by KYBOSH
                                          Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                          No picture but you hear the TV static (white noise) playing loud and clear.
                                          The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                          But it seems they didn't get too far and just left it.
                                          When I first took a look I was amazed at how pristine the inside looked.
                                          Its as if the TV had been in a time capsule.
                                          Caps looked like they were just pulled off the self.
                                          Copper coils had no sign of corrosion on...
                                          02-01-2023, 11:10 PM
                                        • alltvrepairs
                                          Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                                          by alltvrepairs
                                          I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                                          I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                                          Any one met this problem in the past?...
                                          10-08-2025, 07:34 AM
